area-vnode nick-name (for remote IS-IS)
Configures the remote IS-IS Multi-area SPB virtual node nickname.
Syntax
Command Parameters
<x.xx.xx>
Specifies the nickname for the Multi-area SPB virtual node. The value is 2.5 bytes.
Default
The default is none.
Command Mode
IS-IS Router Remote Configuration
Usage Guidelines
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
